Just got boat 2015 115 ob. Changed impeller w shifter in reverse.After re install of lower, I have no reverse. I am waiting on delivery of manual. Would appreciate any advice. Thank you.
Installation of gearcase in neutral will assure that upper and lower shift shafts are aligned properly. Turn the flywheel to mate the driveshaft and crankshaft, as propshaft should spin freely in neutral.
