No pwer at key switch!! HELP 115 hp Mercury
wilson750
I am not getting any power at my key switch, There is power at the starter,but no power is coming back to the switch!! I have searched for a fuse, but come up short!!!
If anyone knows or could help me out!!
Is there any fuse's on a 115 mercury outboard? Its 80's 115hp
Thanks
wilson750
Re: No pwer at key switch!! HELP 115 hp Mercury
Its an 86 115hp Mercury, I bought a new switch also, But i guess i should have tested for power before i went and did that!!
Is there any fuses on the outboard? It would seem there is a fuse that stoped the power from coming to the switch!!
Also there is no power for the power tilt!!
Is there a fuse that is hidden?
hamit59
Yes you have a 20 amp fuse off the Starter Solenoid red wire
wilson750
Where would it be located? Is it tucked away?Would i still have power at the starter? Thanks
Alos how many of the wires that go to the key switch should be hott?
wilson750
Ok I found the fuse and it is ok... I found a hot wire under the console that appeared to be pulled off the key switch harness.. I hooked it up the the one wire that appeared to have a wire in it.. Well it cranks, but real slow!! also the tilt/trim was clicking,but it stoped and doesnt nothing now!! Any Ideas?
:confused:
Chris1956
you would seem to have bad or dirty connections somewhere between the battery and the motor and the ign switch and the PTT Switch. You might clean all connections and maybe things will improve. I cannot help further without some specifics.
Barnacle_Bill
By all means check all your connections. If no problems noted have your battery load tested.
