No prime
paughh.1
I am unable to get my 1962 28HP evinrude to prime. I replaced the bulb and line. I also replaced the fuel lines on motor. It will run when spraying starter fluid in carb. Does anyone have suggestions.
boobie
Re: No prime
Sounds like carb job time. Can you get it to run if you pump the primer bulb ??
stylesabu
Master Chief Petty Officer
Re: No prime
does bulb get hard? is fuel getting to carb? dis connect line at carb to check. if yes to both then as boobie said carb work time
paughh.1
Re: No prime
The bulb gets hard if I disconnect the inlet fuel line from the fuel pump and block the line. There is an air leak sound coming from the fuel pump when the lines are connected. I have replaced the fuel lines and still get the noise at the fuel pump.
