No power !
Ron1958
I have a Mercury 75 hp serial number OG128530
Will not run over 25 mph. Mechanic said the carbs needed rebuilding ? . Rebuilt all 3 carbs and fuel pump and still have same issue. Then another mechanic said the power pack limiter was bad . Then another mechanic said this motor doesn't have a power pack it is one of the coils. Any suggestions ? Can't keep taking it to a bunch of mechanics and each one tells me differently and is getting costly
jimmbo
First you do is check to see if the throttle cable is properly adjusted and that the carbs are opening fully. If that checks out, then do a compression test. Then test for spark using a spark tester. Check timing and carb-ignition sync. Check fuel filters, fuel lines.
flyingscott
Do a cylinder drop test sounds like it is running on 2 cylinders instead of 3. Take a plastic pliers and pull the sparkplug wires off one at a time when they come off they should all affect the idle. The one that does not make a difference is the one not working. You have a powerpak AND 3 coils
