fordmonsta
- Mar 18, 2013
- 5
i bought a 70 johnson stinger motor from a guy at work, had been sitting for quite some time, took carbs apart and cleaned the crap out of em new needles and seats floats and all, now it runs but not well, it will start just fine and idle great out of the water but when i put it in the water it wont even idle and is hard to start, also under full throttle it is a turd, it wont gain rpm with a load on it like it should, runs 7mph wide open, now it did run good for about a minute the oither day, and it would fly, but for a minute is all, i had a bad stator under the flywheel and it would not start at all, i changed that and it runs like i said, but my overall question i guess is would a bad rectifier cause it to be sluggish? i took the carbs back off again tonight and went through em and they are spotless throughout floats are set right and all, what about a bad power pack? what are the symptoms of that getting weak? the fuel bulb stays tight when you are running it also the motor number is 70eslr74m
