I have a commander 302, it runs great when I'm sitting in the slip at idle the problem comes when I put it in gear it always stalls out. I've seen others have had this issue but it seems that no one has posted a solid resolution. I will check the voltage on the coil when I get to the boat tomorrow after work. There's a brand new carb on it and the fuel system is fine. All the wiring appears to be right but I'll double check everything tomorrow. I haven't check the distributor ever is that something I need to check. Any ideas are greatly appreciated.
