No Power Tower Of Power
kingjoe
Have a 115 HP Tower of Power and cleaned out the carbs, tank, fuel pump & lines.... Got her where she idles great however as soon as you try to put in gear and go she bogs down barely breaking 4 MPH.... Any tips appreciated
Chris1956
That is typical of the idle mixtures being set too lean. Start with them turned out 1.5 turns from lightly seated. Now, on the water, with the motor warm, try to accelerate. If she stumbles, open the top mixture screw 1/8 turn and try again. Repeat with middle carb and finally carb, testing after each adjustment. Repeat sequence starting with top carb.
After a while you should find a sweet spot with good acceleration and reasonable idle. Remember idle speed should be about 900 RPM in neutral.
Of course this requires that timing and ignition system are correct and functioning properly.
kingjoe
Thank You Chris.... That was the ticket.... Still need to be fine tuned but at least we have her running...... Look for my video at the link below.....
