No power to starter
yimmyb
1980 Mercruiser 260. I have power to the red wire on the key switch when the battery is on. I have power to the purple wire on the key when key is in run position only, not start.. There is no power to the yellow/red wire in start mode.
the yellow wire with the red stripe starts at the key switch, goes thru the neutral safety switch on your control handle, then to the connector at the motor, then to the pilot relay for the starter, then to the starter.
find out where you are loosing voltage.
Bt Doctur
if you mean no power to the the yellow/red when you turn the key to start, then you have a bad switch
yimmyb
I now have 12 volts to the starter slave solenoid via the yellow wire with a red stripe. The starter still has no power and won't turn over.
Ayuh,...... The starter's solenoid is the next stop in the yellow/ red excite circuit, also a yellow/ red wire,.......
It's the inboard tiny terminal on the top of the starter,......
tank1949
manually jump starter to determine if starter has gone bad. Be sure to disconnect coil wire first. Usually, not having all grounded wires GROUNDED is the culprit. I destroyed a starter drive and ring gear due to poor voltage/amps going to starter via helm switch/breaker. Salt water had corroded breaker internally over years.
