No Power to Motor Trim
tahitiman
I have a Merc 150HP Optimax motor and trying to get it going for the Spring. I hooked up all of the batteries (I had removed them for winter because it is stored outside). I tried putting everything back together but I have no Power for the motor trim up or down either from at the engine motor or from the stick. I charged the battery and it says it is over 13V. When I first started yesterday before charging it would work but weak like a dying battery.
I am really confused. Pls help.
Chris1956
Honorary Supreme Mariner
Re: No Power to Motor Trim
That motor probably has a main fuse, usually near the starter. it may be blown....
NSBCraig
Check your relay pack.
I know there are some real good threads on here about how, but that's where I'd start with the real controls for your tilt especially if switches in two places don't work.
