no power to key switch, 2006 crownline br180
packerman
Hi,
I touched the battery cables to the wrong terminals (kinda dark) when hooking up for the year and now I don't have power to the key switch. (worked when I put it away for the winter). Anyway, I've checked all fuses and they're all good. Power to everything else as far as I can tell, but the key. Anyone know of any secrets about this (then they wouldn't be secrets anymore after you tell me......)? Maybe a special (hidden) "good for business" fuse somewhere??? Any help is appreciated!!!
tashasdaddy
Re: no power to key switch, 2006 crownline br180
what motor?
packerman
Nevermind................. found it. A white plastic block that attaches under battery cable, that is attached to the starter. Then the wires go out through it to the 50 amp main circuit breaker (on the top of the motor). I love it.......... it blows the unmarked fuse before it trips the breaker!!!! Money maker for the dealerships................ Thanks.
