no power to ignition
kmkcolts
i have 4.3 mercruiser tried to start and would only click. The battery was bad so i replaced it. Now i get no click or anything. Have power to the starter but no power to the slave solenoid or 50 amp breaker
alldodge
Check the 90 Amp fuse, it might have blown. Its on the starter post.
If that is good, then check your 20 amp ignition fuse on the red/purple wire going to the key switch under the helm
