No power to guages
jmmla5
I have a 2008 Tahoe q5i. Charged battery. turn on power switch. Bilge pump turns on. Catyls lights turn on. Tilt trim works. Radio turns on and Horn works all while the ignition is off. When I try to start nothing. Turn the key to the on position and the guages do not move. The instrument lights do not turn on either. Can someone please help me out with my issue?
thank you in advanced
alldodge
Going to need a voltmeter. See if you have 12V at the 50amp breaker (both sides of it) which is on the motor. If power is there, find the 20 amp fuse/breaker at the helm. Measure for 12V on the Red/Purple wire going into the key switch
H20Rat
What happened? When did it work last? What is the back story? Did you by chance just put the battery in the boat for the year and accidentally connect it backwards for a split second?
jmmla5
Few days ago. Just took the battery out to charge and put it back in. Did not cross connections I am aware of positive and negative terminals. Just not sure what happened. A storm came in one night and I had to pump water out but that's it. Im thinking a wire or fuse got submerged or something.
jmmla5
Allig I did not find a 20anp breaker at the helm. Any idea of another location
jmmla5
Alldodge I checked the 50amp breaker and with the key off showing 0.01
When I turn the key it goes to 0.00
Could this be bad?
alldodge
Would follow the red/purple wire back to the fuse and is probably an inline fuse
Could this be bad?
This is your issue
There is a 90 amp fuse on the starter post, it looks square and is there to protect the alternator. Put meter on the starter post and you should see 12V.
If 12V is there, then check for 12V on the smaller post off the square fuse (red/purple) wire
jmmla5
You are awesome. That was it. Wow you are good. Thank you very much. Now I Just need to buy one. Thank you again for the help.
Old Ironmaker
I think he will take a cheque. Glad you got her fixed. Good for you. When I have an electrical problem I can't get to sleep, like now. I used to have to call an electrician at the plant to change my flashlight batteries. I am electrically challenged to say the least.
jmmla5
Old Ironmaker I understand. I am familiar with cars and know my way around them mechanical wise. Pretty much the same concept. I am glad I had someone help me out. Will need an adress to send some sort of gratitude. Thank you all for the help
Old Ironmaker
I'll give you my address and I can forward it to AllDodge. Tee hee hee. I hear you, I used to be able to plod around a car or truck. Now I have no idea how to get the huge plastic cowl off the power plant to see what's under it. I have had my Silverado for 8 years from brand spankin' new and have never seen the exhaust manifold, if it has one.
