no power on full throttle
wooddesk44
own 1989 50 hp evinrude. starts no problem and idle no problem. start off in low gear but when opening up on full throttle, motor has no power. I have to chock it from the throttle control with key to get it to full power. worked it like this while tubing with the kids. what could be my problem and should i continue to run the motor like this. i have changed the spark plugs and fuel filter.<br />any help is greatly appreciated<br /><br />Steve
oldboat1
Re: no power on full throttle
sounds like the carb(s) need cleaning or rebuilding -- high speed jet not providing sufficient fuel.
JoesBoats
I had the exact same problems with my 70h.p.I went through all the usual stuff to check and replace and it ended up being WATER in my gas. Imagine that....
wooddesk44
Thanks all for responses.<br />Still looking into the best mechanic that can do the carbs
Solittle
Steve - Don't wait for a mechanic - - do it yourself. If you can handle a couple of open ended wrenches and a screw driver - - you're in.
wooddesk44
Well thanks all for responses:<br />Not to well mechanical inclined<br />Took to mechanic and the carbs had to be rebuilt. The tip on the needle in the carb didnt exist anymore. I had a bit of an air leak in my gas tank hose. Repaired. Also I guess a spark plug was bad in the bottom cyclinder. I found that hard to believe as I just replaced both plugs 3 week ago but the mechanic stated that the plug was defected. If he would have kept it for me I would have returned it. The motor works great now. $219.00 later. Oh well, the enjoyment is worth it. Thanks again all.
