Mariahshabah
- Jul 3, 2018
- 12
Hello, I am the proud new owner of 1997 Mariah Shabah 190se. The boat has a 4.3l x gen with an alpha one outdrive. The boat starts, runs, and idles fine. With throttle only the boat will rev wonderfully. Once put in gear however the boat will not get over 5-10 mph and will not plane. Originally we swapped props hoping the hub was the issue only to end up with the same problem. The boat will reverse fine also. So basically I have no power under load. If anyway could point me in the right direction I’d really appreciate it.
I recently removed cap and rotor and the point were kind of gunked and also the boat was not winterized this last season. As of right now the tach doesn’t work but in “throttle only” I can rev the engine up no problem. It’s once I’m in the water the nose of the boat will raise up but doesn’t have the power to get on plane or speed up.
