Paul_Dublin
- May 30, 2004
- 32
I did a full rebuild of my Yam 60. Rebored and replaced pistons rings etc.<br />Motor started great and idles good and can rev to 3000+ in neutral, but has no power when I put it in forward. Will not get any more than 1600rpm.<br />Heres what I have tried (and no improvement)<br />Just rebored so compression should be good.<br /><br />Pumped fuel line to make sure it's not the fuel pump<br /><br />Swopped Complete Carbs from identical motor to make sure it's not the Carbs<br /><br />Put in new Sparks<br /><br />I havn't checked timing (how do I do this?)<br />I havn't confirmed compression (I am assuming it is OK and feels good when manually turning the flywheel)<br /><br />Any ideas what is causing it to be down on power?<br /><br />As you guys have said.. It's Suck-Squash-Bang-Blow...And I think I have taken care of these!
