Re: no power after certain throttle
I did get your private message but really, a question like this should be answered on the forum.
There are only two reasons why the engine would appear to "be neutralizing" without any gearbox noises.
1. SPUN prop hub. I know you said it is not spinning on the hub but Recheck it. In most cases, it can not be checked by trying to turn the prop by hand. IT MUST be checked with the engine running in gear and the inner and outer prop hub marked.
2. At about mid throttle, the low speed fuel delivery circuit in the carbs stops supplying enough fuel to the engine and the high speed jet and venturi now supplies almost all of the engine's needs. If the prop is indeed not "spun" then the carbs need to be removed, cleaned, and re-synchronized with the timing. If this is the case, go back to the FAQs in the Chrysler/Force forum where you will find instructions for synchronizing.
