I have a 1984 70hp Evinrude non VRO. Thanks joe for explaining the primer solinoid. I have clean the carbs and have check fuel pressure to the cars I have 2.5 lbs at idle and 4 lbs or more as it increses RPMS. I still have now power after idle. It just seems to bog down. This all happen over night. I did get it to run well for about 3 minutes and I thought it was from a sea foam treatment. Thats why I cleaned the carbs They looked clean to me. I am starting to think synk or electrical now. The motor starts in a second and runs for ever at idle and about 1500 rps and the just bogs and has no responce to throtle movement. It will stall if not pull back to half throttle and then it just chugs along about 1500 rpms. I think all the bells and whisles have been long removed. What about the engine limiter for an overheat condition where are these located, to check? There is plenty of water and its not warm!<br />this motor has only about 100 hrs since complete rebuild 2 years ago. I did have a overheat condition last season that could have damaged the limiter????<br />steve
