dazedand confused
- Sep 13, 2002
- 3
I have a 175hp, V6, oil injected Mercury outboard (around a 1985-1987), serial # A943398 that has no power at all when in gear and power (gas) applied to plane it out. It starts and idles okay with the possible exception that it may smoke more then usual at idle. But it "bogs" down (burrrrrrrrr noise) likes it's choking out on power demand. It ran fine when I put it up last fall. I discovered this problem the 1st time I took it out this spring.<br /><br />I've done the following with no success: changed the gas and squeeze bulb, cleaned all 3 carbs, ran compression check, and checked gas/oil hoses.<br /><br />I'm not an outboard mechanic, but I was wondering if this is a power pack problem.<br />Dazed and Confused
