No Master power
menomonie
I'm new to pontooning. I had masterpower (lights, radio & horn) on the way out to a sandbar. Time to come back I had no power. I checked the fuse by the battery. I replaced it but that fuse not for the masterpower, apparently. The only other fuse I found was under the dash. No fuse panel just a black plastice holder holding one red fuse. That fuse was intacted. Anyone have any suggestions of what else I might check before hauling it to a dealer? Palm Beach Super 22 LX SE
Thanks
EGlideRider
Re: No Master power
First, make sure you check the fuses and fuses holders with an ohm meter. A fuse can be deceiving.
You should look carefully for more fuses, because it is not safe to have all of your accessories and lights protected by only one fuse. Plus, it is extremely unlikely that there would be a main line fuse at the battery AND under the console.
If your problem is not a fuse, then you should clean all battery connections and look for bad black and/or red wire connections in the console.
