Re: No Juice
You may have a tired battery(sulphated), weak charging system or something called parasitic drain. Take the negative battery cable off and install an ammeter between the post and the cable. If you get a reading, you have a parasitic drain that will draw your battery down over time. If you have alot of electrical accessories, some drain can be normal. Typically 50 milliamps is a maximum allowed and will flatten an averaged sized battery in 2 - 3 months. If your ammeter shows more than 50 milliamps, keep disconnecting accessories and connectors until the draw goes away, then you'll know where the culpert lies. If your ammeter shows less than 50ma, I would have the battery tested for sulphation and also check the charging system to see if it actually is bringing it up to FULL charge. A weak charging system can lead to premature battery failure, which might be what you're experiencing now. Be sure you have atleast 13.8 volts while running.<br />
Happy Boating!
