So i am still having trouble with getting my 1983 Evinrude 15hp E15RCTA to idle. I have replaced the fuel pump, fully cleaned the carb and carb idle circuites and gaskets, new spark plugs, fresh fuel, and also preformed a de-carb, and turned the adjust screw on the carb cam roller as far as it will go to try to help the motor idle. It seems that I have to advance the timing plate on the cam roller slightly to get the motor to idle. I was reading online that the motor should still idle even though the timing plate is not making contact with the cam roller. Any ideas?
