Re: no idle 90 horse rude crossflow
OB, Its a 1992 tracker 90 horse. no i did not build the carbs as they worked well before the rebuild. i had just noticed, when i was finished rebuilding, that when i closed the throttle using the linkage, the plates were cracked open a bit. so i loosened the to screws on each linkage untill the plates closed, then retightened them making sure the roller on the throttle was against the lever and now it wont idle.I never moved or changed anything that has to do with the timing or the advance rod under the flywheel or where the rod connects to the throttle linkage.
