No idea on which props
Celebrity268
Hi guys, riddle me this. I have an 87 Celebrity 268 but instead of the 3.7 mercs, it has twin 5.7s with Alpha 1s...boat had no props on it when I bought it, so I haven't the slightest idea of what size and pitch to go with. Any suggestions? Thanks!!
Re: No idea on which props
Ayuh,... Throw a set of plain ole 19" pitch aluminium props on it, 'n Try it to get some numbers to work with....
Even if yer wrong, you'll have a set of spares, for Just In Case...
Is either drive counter rotatin',..??
etracer68
Ensign
Hopefully the drives were changed for the 5.7, and the gear ratio is correct.
Celebrity268
Both drives are standard rotation, and are geared right...got them off a friends formula running twin 5.7s
Bamaman1
Find yourself a good prop shop.
If you've got to buy new props, you may as well get the benefit of a person that has propellers as the center of their lives.
They usually know exactly what you need.
