day tripper4
- Jul 25, 2012
- 8
just got boat has sat for 2 years guy ran it in his driveway before i got it. he and i test drive on the lake for half an hour, it started a little rough but seemed to run good. family and i took it to lake started a little hard, ran ok for an hour the would die in neutral but restart on first turn then not at all, killed battery in process, got towed got home charged batt. would crank but not start took off flame arestor and lookd in carb while pumping throttle didnt see any gas started traceing backward water seperator looks brand new (did not remove) fuel pump has bulb on side says replace pump if fuel in bulb (there was none) lines to tank looked good tank looks good seal looks good shot gas out vent when i filled it up (so is good as in not clogged?) went looking for fuses found 5 or 6 in a panel one labled pump sw (is fuel or bilge?) 4 or 5 behind ignition and 2 more in the cluster going down side toward engine all looked ok (i need a volt meter, affordable suggestions?) this is all very new to me are there more fuses somewhere fuel pump should breifly make same noise when key turned to power yeah? it doesnt. whats next or what did i miss or do out of order please help have read many posts both CLASSICGLASS and IBOATS and cant find anything specific to mine. sorry bout run on sentances and number of questions but would like to be back on the lake soon (who doesn't)
cant find hour meter do i have one? where?
so here's my info
GLAB2056M81H-----81 GLASTRON V195 I THINK
5834119-----(ORIGINAL?) 260 MERC, 2bbl carb
so here's my info
