No fire
mvs57
Have a 2000 4.3L mercruiser..will turn over but wont fire...no spark...change coil but still no spark....
alldodge
There are several 4.3's with all kinds of ignition systems, what is your serial number?
Is this a new to you boat?
What happened before it won't start?
What have you done to check for spark?
ROY WILLIAMS
Have a 2000 4.3L mercruiser will turn over but wont fire...no spark...change coil but still no spark....
use a voltmeter ... troubleshoot the coil voltage .
engine cranks and the engine does not run ... no spark ...distributor cap troubleshoot ...
dubs283
Likely a thunderbolt ignition. A few reasons why no spark but most likely is ignition sensor in distributor. Need to verify no spark then follow the troubleshooting guide posted in the stickies
mvs57
replaced that sensor still no spark...leaning towards ignition switch any input?
nola mike
Yeah, follow the troubleshooting guide before throwing more parts at it.
