No fire to plugs
powerboater
How do you test a stator on a 1988 yamaha 130 hp v4 ? I have a good ohm meter, also how to test the power pack ? I am getting no fire to plugs or coil. Thanks for all the help....
99yam40
Re: No fire to plugs
A repair/service manual for your motor will give all steps and equipment needed along with the specs for your motor.
A peak reading volt meter is needed to test those ignition system as far as I know or a DVA adapter and your normal meter to check the voltage inputs and outputs
powerboater
Ok was hoping to find someone that has did these test before . anyone ???
