cblev711
- Mar 1, 2020
- 6
i recently got a 60hp mariner serial number 0g185851 (1995). it hadnt been run in at least 3 years i was told. i replaced water pump and cleaned it up and hooked it up on boat in tub of watger in driveway. put in new plugs and it fired up fairly easily and i only ran it a couple minutes cause it was raining. next day before i took it to lake i started it again and it ran about 3 minutes then just quit. now im getting no spark. ive tested ohms and dva on stator and trigger and everything is within specs. the rectifier/voltsge rgulatror had a burn spot on it and one of the yellow wires from stator had a burn mark at the connection so i replaced voltage/rectifier. still no fire . is it most likley switchbox? and if it is should i replace trigger with switchbox? i9f it makes a difference it has trhe red stator with 2 yellow wires and a green and white/green wires
thanks
thanks
