Hello, long time reader but first time poster here. I have a 1988 Sea Ray Laguna 23 with dual Mercury 135 V6's with the same year engines. The motors are the white Sea Ray editions. After spending $1000 dollars in the spring to get them running "right", the engines ran flawlessly for about 20 hours. The port motor then fell off plane and would not reach 2000 rpms. The port engine had 2 switchboxes installed during the repair. After limping back to dock on one engine I started my troubleshooting. Thinking that since the ignition system was just worked on, I suspected fuel delivery. I changed the water seperators, inline fuel filter, and primer bulbs. I then attached the muffs to see what was going on. The engine would start up and idle very rough, but it was at this time that I saw the bottom carb leaking fuel out of the carb throat. It was leaking out of the bottom "tubes, vents"? I then got 3 carb gasket kits and cleaned the carbs according to the manual.
Again I hooked up the muffs and tried starting it. Although it seemed that I solved my leaking carburetor, the engine does not want to run. On occasion it would start up and rev to 2000-2500 rpms. I would immediatly shut it down afraid to blow the engine but it sounded like not all cylinders were firing. From here I went on to check the compression. All cylinders were well within specs 115-120 PSI. After conducting a spark test using an adjustable spark tester, I found that cylinders 2.4.6 were not firing. I tried swapping the 2 switchboxes to see if the problem would move with the switchboxes but it still would not fire on cylinders 2,4,6. I am not sure if that was proper procedure but I figured that it could not hurt. From here I am not really sure where to go, I am a pretty mechanically inclined person, but the ignition section of the manual confused me and I do not have a DVA meter. I was wondering if someone could give me some pointers and if I in fact do need to purchase a DVA. Can I do proper ignition testing if the motor will not start up?
Thanks in advance for your help.
