No fire on any cylinder
I have searched and tried everything I can that I have seen in these forums and I'm stumped.
I have a 83 80hp Mercury blue line around cover.
I have no fire on any of the four plugs but the motor is turning over fine when turn key, and here is what I have checked so far.
Removed both yellow wires from stator even though I believe those are charging wires. No fire
Removed both black/yellow wires. No fire
Ran wire directly from battery to fuse box. No fire
Tested power from battery to starter and Selenoid. Tested power fine.
Tested the rectifier (which has one red and (two yellow from stator to it)). Have power on red and the middle yellow no power to second yellow
Where do I go next or is the rectifier or stator bad?
rjcamel2355
Sounds like a power pack issue to me.
Go to CDIelectronics.com
Find your particular motor, and test the stator Per their instructions.
However, Like I said, I believe you have a bad switchbox/powerpack and/or a loose or bad connection.
merc850
You're going to have to supply a ser. nr. for more specific help, there are distributor models and non-distributor ones.
Chris1956
A 1983 four cylinder Merc would normally have ADI ignition with 4 coils and a single switchbox. Power to drive the ignition originates from the stator, and the battery plays no role in ignition.
The CDI Electronics web site has a troubleshooting procedure for your motor and CDI sells replacement parts.
Make sure the black/yellow wire is not grounded, when the ign key is on. That wire is designed to kill the spark, when the key is shut off, it is grounded. Disconnect it at the switchbox and see if spark returns.
