i have an 1993 mercruiser 4.3 chev v6
it's been running great till friday night.it just quit,spins over fine and is getting fuel but won't start.
i put a screw driver in coil wire boot and held over distibutor cap and see no visible arc.
we bench tested the coil granted i,m unclear exactly how the numbers should read, but from terminal post to post i'm gettin 2.2.and from center post to either terminal 10.5-10.8.
i'm stumped.do i need a coil or is there something else to check for?
also will a regular gm coil do the trick?
thanks ronnie
thanks ronnie
