no fire after washing motor
sambrigman
I just got this 1986 40hp evinrude, it starts right up.. until I washed under the hood, engine degreaser and a water hose. What have I done? No fire to the plugs at all. Any ideas? Any suggestions greatly appreciated. Thanks guys..
coolbri70
Re: no fire after washing motor
how long did it dry after :confused: some of the ignition parts need to stay dry, you may be able to dry them in the oven at its lowest setting, do a search on how to pickle an engine that's been dunked, I saw a video on this on youtube, it may help with more specifics http://www.youtube.com/watch?v=RBxN5vXTVzc
bonzoscott
Engine degreaser is meant to be sprayed on while motor is hot. I personally then use water from a coffee maker, poured at a slow steady stream. If you blasted with cold water from a hose, could be the dissolved grease got into some connectors for the electric. Unplug any connectors, clean with spray electric cleaner, compressed air , then coat with dielectric grease and try again. I degrease while running with solvent, hot water and compressed air.
