No engagement
Johnny1969
I was out today in my 92 bayliner 1950 classic 3.0 alpha 1 pulling a tube made a slight turn and it flet like a hard pull then all is a sudden the Rpms went up like it come out of gear I backe the throttle back to neutral and then tried to go back in gear and nothing forward or reverse don't even sound like it's engaging no noise at all rpms go up but prop not turning where do I need to start looking
Bt Doctur
outdrive oil level and condition
broken lower driveshaft
broken coupler
broken prop hub
missing SS washer on shift shaft missing after water pump service
achris
More fish than mountain goat
Once you have confirmed that the shift shaft washer is in place, put the muffs on it and get a friend/wife/child to start the engine while you watch the water gushing from the side of the muffs. If the water flow decreases as the engine is turned and starts, then the problem is below the water pump (broken drive shaft, stripped lower gears, spun prop hub). If the water flow doesn't change, it's before the pump (spun engine coupler, stripped upper gears, corroded splines, broken drive shaft).
Chris. ...
oldboat1
likely a spun hub. Standard test is to draw a reference line with a marker across the prop and prop nut. Run in gear and check the mark -- see if the line is broken.
