Chrysleriboat=1945r
- Apr 16, 2022
- 4
I have a 15hp 4Stroke Dec 06 Model NSF15B2 electric start tiller outboard. It won't stay in Reverse without holding the shift lever in R. There is no grinding and is smooth shifting but pops out. I've looked at the shift rod to the lower unit and it's got a double pin to connect the rod to the lower unit housing/gear case. There isn't any apparent rod length adjustment as I think it just needs a little more length to stay in reverse. I've also looked inside the case and the shift lock (appears to be a formed plastic with detents to hold it into your gear selection. However, it won't go into the detent for reverse, just sits on the top and seemingly the problem and no adjustment to give the rod a little more length to allow it to go into the reverse detent. Anybody have a solution for adjusting it. Thanks
