Re: Nissan/Tohatsu 4-stroke 18 hp o/b vibration
It is the way it is. I don't own any of the Nissan/Tohatsu 4 strokes, I have a bunch of their 2 strokes, but I have friends with their 4 strokes, and have ridden in boats with them. The key is to understand the concept correctly. I have noticed that on average, all of the 2 strokes seem to vibrate. This is because they use softer motor mounts and dampners. Turn the steering wheel all the way to one side, or even grab the engine to hold it, and most of the visible vibration is gone, you still will feel it though. Most auto manufacturers incorporate things like balance/silent shafts, larger flywheels, smaller displacements centered on intake and exhaust for performance and such to smooth out their engines, Nissan/Tohatsu has a much more straight forward approach. You really don't need the extra moving parts, so why bother. The vibration has little impact on the longevity of the engine, and smoothes out at higher RPM. Look at it this way, why does Catapillar not use corinthian leather in their tractors? Same kind of mentality. Otherwise, they are bulletproof. I often wondered if you replaced the stock mounts with stiffer rubber, what would happen, it may transfer more of the vibration to the transom. For the most part Yamahas are smoother running, but packed in very tight under the cowel. By smoother I mean less vibration, not variance in RPM's. I must say though, it does get annoying from time to time, when trolling for long periods, unless the bite is wide open, but in that case, who's got time to notice such things, fish on!
