Re: Nissan/Tohatsu 4/6 hp 4 stroke cam
Thanks again Elvin - I'll look into this some more. I had to drill out the air hole on my motorcycle carb when I rejetted it, that kit came with the proper drill bit!<br /><br />To expand on WillyB's inquiry:<br /><br />A) If done properly you will not change the air / fuel ratio (mixture,) just allow more of it to flow into the engine. Checking spark plugs for proper color, etc. is a good 'poor man's' method of verifying proper mixture.<br /><br />B) Gas engines run 'best' at a precise air fuel ratio of around 14.5-14.7, known as stoichiometric. If you tune the A/F ratio Leaner (more air) to around 15.0 you will increase fuel economy but decrease power. Maximum output (torque) of any gas engine is reached at A/F ratio of around 13.2; this is quite rich and fuel economy suffers, emissions also increase. <br /><br />New outboards are tuned to meet EPA emissions regulations, meaning they are running right at stoich or possibly slightly lean. A little 'richening' will significantly improve power and be smoother running. Only if you lean it out will power suffer.<br /><br />(P.S. it is 'officially' illegal to rejet any engine certified to EPA regs: cars, trucks, boats, even lawn mowers. All this is just hypothetical!)<br /><br />Many thanks again!
