bayrunner144
- Aug 5, 2012
- 7
Just bought a used NSD40B #023697XE. according to Nissan it is a 2006. the seller fired it up and it ran perfect. I installed in on my bayrunner and it won't start. the engine was laid down on the port side in the back of my truck for an hour bringing it home. I installed new spark plugs(oem). new resistance cap on top plug. old one was corroded. tested the wire. inline spark tester shows spark on all cylinders. recommended marine battery 800CCA 12.8v reading. no warning buzzers. when I attempt to start it, a tiny bit of smoke comes. after several attempts, it has started to backfire. The ignition must be working,right? Not getting enough fuel? fresh fuel, primed til bulb is firm. i watched the fuel filter fill up. I have a Seloc manual but its a bit overwhelming. could laying it down have caused the issue? Any help would be greatly appreciated.
