I have a 2003 Nissan 4s outboard. The tilt brackets are rusted solid and will not move even with penetrating oil. When I say "tilt bracket" I am referring to when the tilt is all the way in up position and you rotate the tilt brackets down to rest on mounting plate to support engine and take stress of trim/tilt cylinder. Solid rod with welded bracket goes through 1 side and other side is held on with a pin. Drilled side with pin to get that bracket off. Shaft with welded bracket will not budge. Nissan used cheap metal instead of stainless or high grade aluminum. Any other ideas on getting this off so I can install new one? Worried about banging on it too hard. Thanks
