schoonerdog
- May 16, 2008
- 3
my nissan had zero coolant flow, dropped the lower and replaced the impeller, but the old impeller looked just fine. This is what happened last year but there were other issues with it not idling properly so I took it to a service shop to get both taken care of. Over the past few years the stream would start off ok, then rapidly diminish. The service shop mentioned lots of salt build up. I've had this outboard in a salt water environment for 9 years, and even though I flush it at the end of the season, I've had yamaha 4 stroke outboards get to the point where they couldn't be brought back because of corrosion in the small coolant passages (they were about 10 or 11 years with lots of salt water use). Any advice to trying to rescue it? Try pouring through white vinegar?
