PrplGld
- May 7, 2005
- 123
I know water should be coming from the idle port when the boat is in the water but how about on muffs? Should there be water from the idle port when water is coming in only through the water inlet screens via muffs?
The manual says to stop the flush "if water does not exit the water stream fitting", doesn't mention the idle port.
