Nissan NS50D Carb air leak?
itchybro
Ahoy from North Knoxville!
Dear Gurus,
I seek your wise cousel sirs. I have a NIssan NS50D that I'm pretty sure has a carb air leak problem. (First 10 to 15 minutes it's running it's great but, then starts getting sluggish and I have to start pumping the bulb to keep going.)
I have 2 new tanks with new lines and fittings. I don't think they're the problem.
I'm assuming a carb kit (gaskets etc.) should cure me. The only one I've found online seem to be missing some gaskets. Do you folk have a source you can point me toward?
Thanks SO much for your time.
Phil
Knoxville
Sea Rider
Welcome to Iboats,
Any Nissan/Togatsu dealer should have those requested parts...First 10-15 minutes works fine at idle, fast idles while running at which throttle setting ? If need to re prime probably fuel pump diaphragm shortly will have its Waterloo Time. Check fuel pump diaphragm condition if dried, worn, severely ballooned, cracked. If so, change.
Are all 3 carbs immaculate clean and in good working order ?
Happy Boating
itchybro
Carbs should be in pretty good as there was serious service at the beginning of last year and it was only taken out about 5 times. Thanks for the fuel pump diaphragm tip!
Sea Rider
On 2 stroke engines is better to consume all fuel leftovers on carbs, will guarantee free accumulations of oil deposits when fuel has evaporated. Flush engine on muffs for 2 min, disconnect engine fuel connector, let engine die. Will give some + minutes running time after disconnection. If fuel pump diaphragm is spot on, probably have a gummed carb ?
Happy Boating
pvanv
CARBURETOR REPAIR KIT: 40D ~ 50D2 2-STROKE
Carburetor repair kit. Kit includes gaskets, float & needle valve. One kit repairs all 3 carburetors.
Fits:
40D, 40D2, 50D & 50D2 2-stroke models.
Note: picture may not be of actual kit
Part #: 3C8871222M
List Price (MSRP): $168.62
You may also need fuel pump bits. Either you aren't pumping well, or you are sucking air at an o-ring or similar location. Also verify that the fuel filter isn't leaking air (and isn't clogged).
