Trilogyinc
- Jun 3, 2017
- 22
Hello to all! This motor is eating me up. Nissan NS40C. Starts easy..idles fine..give it the juice and it just breaks up.it has gotten on plane a few times but not lately. It doesn’t seem to bog just pops and sounds like it’s overloaded. New battery, new cdi, new plugs, carb has been gone through about 6 times now, timing is set by the manual, I decarbed the motor also. Changed fuel pump thinking it might be leaking in the crankcase. It does it with a 10 pitch prop and the 15 pitch I tried.. I just ran it and I’m about to pull the plugs and check compression again. And if you hit the choke when its breaking up it will turn off. Thanks for any help someone might be able to give me.
