Helgaiden2
- Jun 25, 2018
- 8
Hi all,
so its time i do some maintenance on my mini-boat which has a Nissan NS25c outboard (same as Tohatsu NS25b from the same time i believe), which appears to be a late 80s/early 90s model i think. The boat itself is registered as a 1986 model. Last i tested, it still expels water so the impeller is still doing its job, but i've got friends more knowledgeable than I in boating advising i change to be on the safe side (in the time i've owned it, i never changed it though the boat hasn't gotten a whole ton of use either). Here is a picture of the engine (not mine specifically but its this model, though mine appears longer)
So im not sure but cant seem to find the right impeller for my needs. I think this might be the right one though and was wondering if any of y'all can help me out a little bit in finding what i need?
https://www.ebay.com/itm/Outboard-W...054641?hash=item2cb3707cb1:g:-K0AAOSwFe5X1lk8
Another thing when changing the impeller than im not sure i'll need is the lower unit gasket kit that i've also seen while trying to find the right impeller. This came up, but it says its for the NS25c2 which i dont think my engine is:
https://www.ebay.com/itm/For-TOHATS...328208?hash=item1a29da64d0:g:FzMAAOSwWxNauFZk
I discovered the carb also has a torn seal as well and was trying to find a carb rebuild kit without much luck, i keep striking out on that one.
Now up until this point, i haven't really had any issues with it. Just trying to stay ahead of any failure.
So im hoping maybe some of you more knowledgeable than I can point me in the right direction. None of my buddies have outboards, let alone 2-stroke engines so their help can be a bit limited.
At least there is this video that will help me in getting the impeller changed as it seems to be my exact engine too.
https://www.youtube.com/watch?v=HRHVI4W-4cY
Thanks in advance...
oh and here is a pic of the boat
