gerald trentham
- Sep 27, 2006
- 22
Where can I get puller flywheel removal tool
Herra said:You can make it by-your-self, drill 3 holes in a flat piece of rigid metal, distance from hole center to center of plate is 38 mm screw 3 bolts tighten up and hammer, pop it is open, the nut is 27 mm and you need to lenghten the shaft to get enough torque, you also need something to hold the flywheel in place, good look tuning you stuff.
d I´m the # 1 you see (almost everyone here in my neighbourghood is),
Trust me, I know what I´m talking about.
http://www.gumboracingteam.com/grt/?show=35&p=News_forum/1
Herra said:Gerald you are right about me being # 1o
but are you quite sure of what you are doing?
Did you have any spark before you started tuning or did you loose the spark by tampering with the flywheel? Did you loose spark on all cylinders?
Mr. Playboy had a good spark when he turned the engine but with the engine running it was to weak, if you have no spark at all, what so ever, you are probably in deep shi.. trouble!
If you want I can give you complete troubleshooting advice for free, no trouble at all!
after following the troubleshootin´ chart your engine will run and that is 100% for sure.
You have to send me a Private Message I am not posting it here, against Tohatsu policy.
Herra said:You are right about PMs,
I just fixed :=it now it should work!
