Re: nissan 90 A????
GIve it time.. Not a whole lot of action here on the Nissans and Tohatsu. I am a new owner of a 90A myself and just getting to know it..
Maybe a better description of what is happening would be a good start.
When you say surging, do that mean the the RPM is going higher that the normal RPM for brief periods or does it mean that it dips. Different thinking would go into each of these answers.
If it is dipping, then I would carefully evaluate the fuel lines in front of the pump for leaks. It can suck air and that would cause a kind of undualting RPM.
If this is surgin over the normal RPM, then are you having issues with ventilation or the prop??
Again a little more detail will help.
