Re: Nissan 9.9 hp 4 strokes
Maybe I found the explanation to the question I asked. While surfing on the net I found this description of the exhaust system<br /><br /> "All cylinders dump exhaust into a common manifold where water is introduced to cool and muffle it. The exhaust-water mixture then passes down a passage in the drive unit and eventually exits through the propeller hub. When a boat is at idle or slow speeds, however, the static water around the prop produces too much resistance to the exhaust, resulting in excessive backpressure. (When the boat is moving, a low-pressure area behind the propeller prevents this.) To alleviate this problem, one or more passages are cast or machined into the intermediate housing just above the waterline. If pressure builds at the prop, the exhaust can escape through these ports. If these ports are restrictedsay, by overloading the boat to the point where they are submergedexhaust wont escape, cylinder temperatures and pressure will rise, and deposits will form."<br /><br />I was testing my outboard in a buccket, which may create a back presure and force some of the exhaust through the relief port.<br /><br />Cheers
