As of today this motor will not start. In the last 2 months this motor went from,
- running like a new motor to...
- running rough (new plugs seem to clear that up) to...
- not wanting to start (starting spray would get it going) to...
- to not wanting to start almost immediately after starting on the first pull, to...
- starting fine hours or days after not starting but once again not starting later in the same day.
I have replaced the plugs, verified the spark and compression, replaced the fuel line, filter and pump bulb, cleaned the carb/replaced internal parts, the oil level is fine, etc.
Now the motor will not make an effort to start even with starting spray. Is the CD/power pack a suspect?
Any suggestions would be appreciated.
