Nissan 8hp Exhaust
1985bluefin
Hey guys I just picked up an 8 hp Nissan and took it out on the lake to get some freshwater running through it(it was used primarily on a sailboat). I noticed that not all of the exhaust isn't coming out by the prop, some is coming out by the powerhead. What does this mean? Could it just be plugged up a little? Or is this a major fix kinda deal? Thanks for any input you guys might have.
pvanv
Re: Nissan 8hp Exhaust
What is your model/serial?
If the exhaust is exiting from above the waterline, on the back of the leg, through a small hole or two, you are probably seeing the exhaust relief at work. That's normal. If it is leaking inside the cowling, you likely need a new base gasket.
1985bluefin
Model- NS8B
Serial- 78931
It's leaking inside the cowling for the most part. It wasn't running up to par and when I took the cowling off there was a bunch of exhaust inside. Once I took it off and ran it with the cowling off letting it get some fresh air, it picked back up and ran fine.
Sea Rider
Before changing base gasket, retorque under shaft housing bolts, maybe a bit loose, if not, change base gasket, seal gasket both sides properly with heat resistant silicone, mega gray type.
Happy Boating
