Nissan 8hp choke/throttle problem
WHISKEYTRAIN
I have a 99 nissan 8hp that will only run full throttle while at half choke. Also the idle is bogging out and it doesnt seem that adjusting the idle screw does anything. The motor will shut off a lot while trying to be put into gear. What is causing these problems? Are they related?
pvanv
Re: Nissan 8hp choke/throttle problem
Clean the carb properly, and you will likely be OK.
