I have a nissan model ns55b 2 cylinder engine serial no. 353-113906 .I think it is 1985 or newer not sure.I bought a tachometer off a newer 3 cylinder nissan.hooked it up and the most rpm it will show at w.o.t.is about 2800 r.p.m. will this tachometer work on a 2 cylinder engine like mine or 3 cylinder engines only? I hooked the wires up yellow to yellow and white to white and black to black is there another way i should hook it up.i used the yellow and white wires in the control box to hook the tachometer too. thanks
