Nissan 50D waterpump
Lo
The lower unit is removed. Four long screws are out of the water pump. I have worked the water pump lose. The water pump has a gasket about midway down. Should the top part of water pump down to the gasket be removed or does the whole thing come out? Need to change impeller only. Help will be appreciated.
TOHATSU GURU
Re: Nissan 50D waterpump
Just pull the plastic housing up and over the driveshaft. That will expose the impeller.
